2008 ac intermittent
Old Sep 4, 2025 | 10:45 AM
Motohead's Avatar
My AC has always been great blows COLD recently I’m experiencing interment issues where after about 10 min of driving (from cold motor) I get warm air if I park it for a wile I’ll get cold air again (for less time 2-5 min) I’m wondering if the radiator fan isn’t coming on and the system is over pressurizing causing the pressure switch to turn off the system. Is the radiator fan supposed to run constantly whenever the AC is turned on or does it cycle ?
Old Sep 4, 2025 | 11:11 AM
Is your CheckEngineLight on?
Old Sep 4, 2025 | 11:30 AM
If you have P0128 WHEN THE ac IS NOT WORKING you need to replace your t-stat with ACDelco 131-158 ONLY..
Old Sep 4, 2025 | 11:46 AM
Motohead's Avatar
yes with a trans shift solonoid code my overdrive solenoid is bad. I haven’t replaced it yet.
Old Sep 4, 2025 | 11:47 AM
Motohead's Avatar
no, no 128 code
Just a transmission shift solenoid code
Old Sep 4, 2025 | 11:49 AM
Motohead's Avatar
Do any of you guys know does the radiator fan run continuous when the AC is turned on or does it cycle?
Old Sep 4, 2025 | 01:25 PM
LS/LT the fan should run whenever the compressor is running. If the compressor is turning off, the cooling fan may turn off.
Not sure about SS, it has different rules for the cooling fan. Pulse Width Modulated.
Which trim level is your HHR?
Old Sep 4, 2025 | 01:28 PM
Motohead's Avatar
my fan is running when I turn on the ac i’ll take it for a drive and check after the AC malfunctions
Old Sep 4, 2025 | 02:54 PM
PulpFriction's Avatar
My SS a/c would quite intermittently when the refrigerant got low due to a tiny leak in the compressor. The light on the a/c switch would go out when the a/c quit. Sometimes pushing the button would turn it back on, sometimes not. It quit with increasing frequency until some refrigerant was added. That fix lasted a couple years. Then the a/c quit again, but the light on the button stayed on. See.s to have been the clutch. Got the compressor replaced, works fine now.
Old Sep 4, 2025 | 03:00 PM
Motohead's Avatar
interesting my light stays on
when it quit the second time, did it quit for good or was it intermittent
