2008 fluctuating temp Gauge and stalling
You could try pulling and resetting all the fuses and relays. This has worked for others.
If that makes no difference, you could try searching the car’s wiring for damage by rodents or other causes.
Keep in mind you’re working on a 16 or 17-year-old car.
I'm having someone come out with a better scanner and more knowledge then me to figure this out I looked at all relays and fuses and all connections with no luck.
The coolant will crystallize over time, Dexcool has just a 5 year lifespan. The thermostat will fail because of that . In my experience it’s the simple things that cause problems most of the time.
It’s just my opinion from 60 years experience working in cars , the beauty is that you can take it or leave it, but bear in mind we’ve been diagnoseing HHR issues since 2015.
