2008 HHR 2.2L Suitable Engines.
Old Jul 7, 2018 | 04:23 PM
cpirrmann's Avatar
Hi All,.Does anyone have a definitive list or definitely know which ecotec 2.2l model years and out of which cars and model years will fit in a 2008 HHR?
I have seen a few posts for a particular engine swap but not a good list to have when going engine shopping.. Mine jumped time and chewed itself up. Pistons holed, cylinders gouged, valves busted up, etc.
Thanks
Old Jul 7, 2018 | 04:29 PM
Welcome to the site, check out post #5 in this thread
https://www.chevyhhr.net/forums/2-2l...ne-swap-57389/
Old Jul 7, 2018 | 05:20 PM
cpirrmann's Avatar
Thanks Oldblue,
. I read that but wasn't sure. So the engines in Jimmy68's list are all compatible with the 2008 HHR 2.2L?
I may be thick but he mentioned the Saturn Ion would work but it wasn't clear to me that the others would,only that the L61 was used in those cars.
The different HP also threw me off. So, the L61's from those models and years are interchangeable with the 2008 HHR 2.2L?
Also, what about newer model year 2.2L backwards compatibility?
Old Jul 7, 2018 | 09:14 PM
Newer backwards is a negative because of the VVT added in 2009
Old Jul 7, 2018 | 10:38 PM
Some of the earlier other applications had a cam takeoff for power steering that might be a problem.
Old Jul 8, 2018 | 07:45 AM
cpirrmann's Avatar
Thank you all for the info.
Old Jul 8, 2018 | 09:50 PM
2007,08, would’ve been switched over the electric power steering.
928HHR
Nov 22, 2017 09:47 AM
Banana hands
Mar 28, 2014 11:48 PM
aven11
Jan 26, 2011 06:49 AM
tplyons
Dec 2, 2010 11:20 AM
