2008 hhr ac compressor
Old Jun 30, 2019 | 04:08 PM
Of course, we should ask if all of the controls are set properly. Temp knob all the way blue, fan on, blowing in face etc.
Old Jun 30, 2019 | 04:25 PM
drscott's Avatar
As I said I'm done for the day, but one thing I did ,as in in construction is hose down my condenser and radiator and got alot if dirt out, so now waiting for my fan to kick on
Old Jun 30, 2019 | 04:26 PM
Abra-Cadabra
Old Jun 30, 2019 | 04:35 PM
drscott's Avatar
I wish!!!! Still no ac but electric fan works! No magic there!!
Old Jun 30, 2019 | 04:57 PM
If you're curious where the pressure switch is, it's on the hose block at the compressor. (round silver thing inside the circle)
Old Jun 30, 2019 | 05:37 PM
  #26
He said that was replaced.
If somebody put a fuse in place of the diode I don't know what would happen.
  #27
drscott's Avatar
Thanks, it is connected but cant find the diode for the compressor, but then again I'm indulging in adult beverages for tonight, if you can find me a picture of where that is it sure be helpful sir.
Old Jun 30, 2019 | 05:45 PM
  #28
There is a drawing in the owner manual, also a diagram on the inside of the fuse block cover, underhood.
Old Jun 30, 2019 | 06:20 PM
  #29
drscott's Avatar
The thing I pulled out of #9 I replaced it with the headlight one, it has the same numbers but when I did that it was extremely hot, so I put the original back in and that one was hit as well.
Old Jun 30, 2019 | 07:16 PM
  #30
Well now something is probably burned up. Diodes are NOT the same as Fuses. A diode blocks the flow of electrons in one direction a fuse lets them go either way.
