2008 ls - bcm
i purchased a new factory center bezel WITH fog light switch to hook up the wiring to..so i wanted to know if they can be wired to this switch bypassing the BCM or does the dealer have to get involved with flashing..
The dealer was able to program my 2007 LS for fog lamps with no problem. I have heard that some can't be programmed. It may depend what version bcm you have. Best I can say is to take it to your dealer and see if they will try. Most dealers will help you if they refuse try a different dealer.
You can wire it to bypass the bcm I did not. I did have to run a wire from the relay under the hood to the bcm because my 07 was missing that one wire.
im going to bring it to a friend of mine who does custom audio installs he said he might be able to bypass as well..just dont want it to fail or mess something else up
Sorry i didn't understand your question Installing the fog lamps like factory and flashing the bcm gives you the dash indicator when the fog lights are on and only lets the fog lights work with low beam only. It is just user preference I wanted mine to look like the fog lights came from the factory.
