2008 lt2 half panel ac/heat not working
So I have a 2008 lt2 half panel and the ac/heat is blowing air at the off position when I switch to any speed it doesn’t blow. I replaced the resistor this morning and still not working properly. Has anyone else had this problem? Any guidance will be appreciated. Thank you for your time to read this.
Check the back of the HVAC panel in the waterfall , remove it and look for melted connections. See post #8 in here
https://www.chevyhhr.net/forums/prob...control-63603/
WhoDat
May 14, 2022 09:55 AM
