2010 door vs 2011 door
Old Sep 26, 2022 | 11:58 AM
RiskyT's Avatar
Hello all,
I have converted my hhr into a tiny home which I've been living in for 2 years now. Last night my car was broken into. They broke a window and bent the frame of the window as well.
I found a 2010 hhr at a pick and pull, but I'm unsure of the compatibly.
My question is, will a 2010 hhr door fit on a 2011 hhr body?
Old Sep 26, 2022 | 12:43 PM
Yes, 2009 thru 2011 LS/LT doors and 2008 thru 2010 SS doors are compatible.
Old Sep 26, 2022 | 01:04 PM
RiskyT's Avatar
Thanks for the info! 🙏
Old Sep 26, 2022 | 02:35 PM
You’re welcome.
Old Sep 26, 2022 | 03:57 PM
Lonwane's Avatar
From my understanding ALL of the doors are the same.
Except the 'Panel' version, which has no glass and different door cards.
It's the wiring inside the doors that is different.
Old Sep 26, 2022 | 07:15 PM
The 2006 thru 2008 LS/LT have different bracket areas for the arm rest area the newer door card panel will not fit.
Old Sep 26, 2022 | 09:13 PM
That's good information, thanks Oldblue!
Due to the relocated window switches, no doubt.
Old Sep 27, 2022 | 07:37 AM
Yes, the move the door switches was the reason
Old Oct 6, 2022 | 04:26 PM
PulpFriction's Avatar
This is a good place to mention the SS got the new design a year early, so they’re all the same, 2008-2010.
Old Oct 7, 2022 | 05:39 AM
I did post that read post #2
