2010 HHR Oil Idiot Light, engine dies
I understood that from the onset Whop.. I was saying that perhaps that was the case. Sh*t happens and we've all gotten marginally lazy. The proof of that is in the numerous duplicate threads regarding long solved issues, because no one wants to search, they just want to ask and get answers...
Mostly the "younger" generation (as someone dedicated a complete thread to) I believe. Most all want everything given or done for them
Most have not read the Owners Manual for example.....or acquire one if the don't have it. And if you did, and understood it, you would not have made the mistake with the OLI intent. JMO
I'm done, in before the lock....way off topic and we were warned already.
The OP has not been back to this thread since post #3 and therefore I ask, has any of this assisted in the original problem of low oil stalling out after a short distance?
Is it really an "idiot light"? Maybe it's a "too lazy or too uninformed to open the hood until it's too late light"?
Or, as I've heard proudly proclaimed "all I know is put gas in it". Hang around a service station for a while and ask people "how do you open your hood?".
Your engine could have low oil pressure or the sending unit might be giving a false low pressure signal. I would try the sending unit first or install a mechanical gauge to check pressure. If a new sending unit doesn't fix the problem I think these engines have a timing chain tensioner that uses engine oil pressure. If that fails it could leak enough to drop the oil pressure. If the oil level was low for a long time, you might have damaged the engine. If you have the oil changed at a quick lube, make sure you check the level to make certain they filled it to the correct level.
Jimmy~O
Oct 8, 2013 02:39 PM
Lone Ranger
Aug 11, 2008 09:43 PM
