2011 AC Blower motor replacement
Old Oct 6, 2019 | 10:21 AM
Timewalker's Avatar
Hey all. My blower motor was off and on back in July. Whacking the dash worked for a while, but I think it's time to replace it.
I watched this video https://youtu.be/5Kcr22ATpAE and it said it was easy to cut out the old blower gasket type plastic between the two motor and housing, but on mine there appears to be a much more solid section of plastic next to the connector bridging the gap. See photo.
Am I supposed to cut through that as well? Will a sharp knife do it or will I need a saw?
It's already a tight fit under there.
Thanks.
Old Oct 6, 2019 | 11:12 AM
The instructions say "between the circular ribs".
Old Oct 6, 2019 | 11:17 AM
Timewalker's Avatar
Ok, I took that to mean the area between the screw holes. Am I wrong?
If so, where should I be cutting?
If I am right, there is still that solid part going across the two pieces.
I'm confused.
Old Oct 6, 2019 | 11:25 AM
Look at post #16 in this thread https://www.chevyhhr.net/forums/prob...l-18288/page2/
I have never done it. Here is the pic from the shop manual.
Old Oct 6, 2019 | 11:31 AM
Timewalker's Avatar
Yeah, that looks like the area I am talking about.
Sigh.
Maybe I will just take it to the shop tomorrow.
Old Oct 6, 2019 | 12:00 PM
Why?
Old Oct 6, 2019 | 12:02 PM
Timewalker's Avatar
I'm hesitant to cut through part of it, and not be able to finish it, I guess.
Old Oct 6, 2019 | 03:18 PM
Lonwane's Avatar
The cutting part is not that difficult WITH a sharp knife blade. If you started the cut you can finish it. Cut a little and look, then cut some more. I did at 62 years old.
Paying 50-60 bicks an hour (or whatever the rate is) is just plain silly.
Get'er done
Old Oct 6, 2019 | 04:08 PM
Timewalker's Avatar
Get'er done
Thanks. As soon as I went back outside, it started raining. I guess I will try tomorrow afternoon.
Old Oct 7, 2019 | 09:45 AM
Wear gloves, take your time and cut carefully, very carefully.
