2011 Chevy HHR LT Humming Under the hood
Old Aug 9, 2017 | 08:45 PM
electronik2408's Avatar
Hello everyone, I have been having an issue where my car is making a "humming" noise coming from under the hood. It does it under idle and low load. If i step on it, it goes away. I cant seem to figure what it might be and i don't want to replace parts that aren't the problem. Has anyone had this issue before?
Old Aug 9, 2017 | 08:56 PM
Welcome!
My guess would be either the A/C compressor, the alternator or the belt tensioner. OR, if there is an exhaust smell look at the flex pipe
You can get an automotive stethoscope for about $3, or do the long stick to the ear thing.
Old Aug 9, 2017 | 09:12 PM
to the forums!!
Yes, stethoscope or long handled screwdriver. I like the long funnel myself. Small end to the potential problem, big end to your ear. Maybe make a video and post it here so we can hear it.
Old Aug 10, 2017 | 07:51 AM
Welcome to the site, is it a metal to metal sound? Does it change with RPM increase or decrease? A 2011, do that narrows it down to 2.2 or 2.4, automatic or standard??
Old Aug 10, 2017 | 09:24 AM
Originally Posted by donbrew
Welcome!
I will purchase one today. Its a high frequency squeal so its kind of difficult to pinpoint the source by ear for sure.
Old Aug 10, 2017 | 09:25 AM
to the forums!!
I will post it when I get home.
Old Aug 10, 2017 | 09:28 AM
No it doesn't sound like a metal sound. No it does not change with RPM. It eventually goes away with a heavier load. So during idle, you can hear it. During light throttle, you can hear it. During heavy loads, it goes away. Pitch doesn't change. Its a 2.4 automatic.
Old Aug 10, 2017 | 09:37 AM
Hmm. Since it doesn't change with RPM, then it's a constant source creating the noise.
My guess would be a PCV issue. Constant vacuum at idle and light throttle. No vacuum at heavier throttle the noise goes away. Maybe Donbrew can confirm my guess and tell you what to check.
Old Aug 10, 2017 | 09:49 AM
How many miles?
Old Aug 10, 2017 | 10:02 AM
How many miles?
it has about 120,000
