2011 HHR Turns on Won't start...?!?!?!
Old Aug 7, 2014 | 05:37 AM
To add to Lucky's post:
Careful. DO NOT ground out that cable to any metal parts of the car. That is the positive battery cable.
Old Aug 7, 2014 | 10:30 PM
Lucky's Avatar
Very good point. Thanks.
Old Aug 8, 2014 | 06:52 AM
Welcome to the site, please let us know how the battery test went, I had this same issue a few years back while on vacation in Florida, it was the battery, it had a bad cell or 2 it was the original battery just 3 years old.
Old Aug 8, 2014 | 08:38 PM
I don't remember; did anybody suggest the old fuse box halves thing?
Yes, Laco did!
Start with tightening the 4 bolts under the fuse box cover.
Old Aug 10, 2014 | 01:07 PM
CokeZero's Avatar
Take a gander at this.
https://www.chevyhhr.net/forums/prob...p-50543/page2/
Old Sep 15, 2025 | 07:18 PM
JJP New HHR's Avatar
I had this same No Start problem on our new aquired 2011 2.4L LT.
What I did in this order and I rechecked for improvement after each step.
Fully charged battery and verified voltage.
Checked all fuses in underhood fuse block.
Cleaned grd connection left frt on radiator support, behind A/C hard line.
Cleaned pwr connection (Torx Screw, pwr steering motor) at underhood fuse block.
Cleaned power connection to the left of the underhood fuse block.
Loosened and retightened the 4 10MM studs in the underhood fuse block.
Replaced the battery.
Problem resolved (so far).
I do not know the age of the battery but it was an AC Delco and it did not look very old. Both end cells looked puffed out/swollen. That is usually a sign of problems inside the battery.
Old Sep 16, 2025 | 07:43 AM
The torx power is for the electric power steering motor, there are 4 bolts holding the under hood fuse block together
Old Sep 16, 2025 | 09:29 AM
The chain auto parts stores will perform a free battery load test and charging system test
Old Sep 16, 2025 | 12:37 PM
Bulging cells indicates overcharging or freezing. It takes REALLY cold to freeze a battery.
Get your charging system checked.
Old Sep 16, 2025 | 01:16 PM
That new battery won’t last if the alternator doesn’t charge it.
