AC blows weak or stops in Reverse
Old Nov 22, 2021 | 11:48 AM
Specifically fuse #4 and relay #30, both on the BCM.
Old Nov 22, 2021 | 12:00 PM
Originally Posted by Hawkeye3636
Little update. Discovered when it cuts off if reach down and lightly push on bcm it kicks back on instantly. Something loose in there maybe?
The bcm wouldn't need to be reported for a blower motor would it. That seems silly.
" reported " ? What are you asking ?
Not only will it be reported, this will be on permanent record!
Old Nov 24, 2021 | 02:39 PM
Hawkeye3636's Avatar
That should be reprogrammed. This problem has had me bang my head against the wall a few times. Might have brained my damage. Also always check your autocorrects folks.
Old Nov 24, 2021 | 03:40 PM
Tell me about it! I’m always getting corrected!
Old Nov 24, 2021 | 04:56 PM
Since I retired from the fire dept. several years ago, I needed something to do.
I then took on the title of Spelling Police.
Old Nov 24, 2021 | 04:59 PM
Ah, you’re the one, that have always dreamed… naw that’s the Dream Police!
Old Dec 13, 2021 | 11:36 PM
Originally Posted by Oldblue
Press all fuses and relays firmly into the interior fuse pane. They can shake loose over a period of time.
I did this and worked for like a month and now loose again. Any suggestions on how to keep it from coming loose all the time?
Old Dec 13, 2021 | 11:44 PM
Tighten the bolts.
Old Dec 14, 2021 | 06:59 AM
https://www.chevyhhr.net/forums/how-...rmation-59520/
Follow through this how to.
Old Dec 15, 2021 | 01:07 PM
This looks like the under the hood one. The relay that's shaking loose for me is on the bcm.
