AC Cold but not Blowing - Air Trickle When Driving
Old May 14, 2022 | 09:55 AM
greg8453's Avatar
Originally Posted by WhoDat
Well the first problem that showed up months back, was that it would only blow on high.
That would be a failed resistor block.
But I mentioned the issue with the AC only blowing at high before it ultimately shut off, in case that helps anyone diagnose the root of the problem based on what happened first.
So it will not blow at all? That has direct B+ which is why it only blows on high with a failed resistor block but to not run at all we need to check at the fuse.
I do have a non-contact voltage tester pen (12V-1000V/48V-1000V). But I've only used that to diagnose issues with AC outlets in our home. I don't know enough about electrical diagnostics to know if it would even work for a vehicle.
Those will only work with AC.
This is a test light.
Amazon Amazon
Mike's 2007
Maintenance and Upkeep
25
Jan 20, 2022 02:09 PM
SullyinCT
Jul 22, 2019 07:10 PM
Steve Allen Walls Jr.
May 27, 2017 10:54 AM
skyline26
Aug 25, 2012 06:33 PM
laborkei
Jul 30, 2007 11:47 AM
