AC Draining onto passenger floor/carpet
I've discovered difinitively that the AC is draining onto the passenger floorboard, and likely one of the reasons why the original owner decided to sell it. Seems to be a mysterious leak if you don't know how to seek and find the issue, or go to the dealer, as I can imagine most basic mechanics would blame something else or try to get you to replace major parts = Major costs. So far, I've ruled out the small undulated "J-shaped" 10mm removable rubber hose that goes from the AC motor up into the casing (I blew into it, and there is no air leaking out). There is a black, flat square plastic coated sensor about 2"x2.5" square that is removable right against the firewall that has a plug into it. The sensor seems to be loose, as the teeth on the housing side seem to be partially broken, and it sort of hangs there. I am guessing that possibly water leaks through the seal, as it's no longer tightly fitting. The other perplexing thing about finding this issue, is that it doesn't want to leak water while the car is sitting idle. It only spits out while the car is moving.
At least I've discovered that there is no leak from the cabin filter area, as I replaced it with a new charcoal one, and it was dry, plus I removed the cowl, cleaned out a couple leaves, wiped out and cleaned the insides, and lubricated the joints of the wiper arms, motor, etc... I now know the leak is not from the cowl intake. I'm going to re-investigate this issue and spend time trying to figure it out. Any suggestions or ideas are always appreciated! I'll be back with pictures. |
If that is a 2006, search butyl patch. Otherwise unstop the A/C condensate drain
Originally Posted by donbrew
(Post 885889)
Next to the blue mark
https://cimg3.ibsrv.net/gimg/www.che...0e44f14ced.jpg |
You don’t need to try to reinvent the wheel, dozens of posts and videos, showing how to clear that AC drain hose online.
https://www.google.ca/search?q=hhr+a...&client=safari most are from the top, no need to lay on the ground. |
I think you are talking about the fan resistor pack. There should be a clip for it.
#2 https://cimg3.ibsrv.net/gimg/www.che...94a5f1eddf.png |
Originally Posted by Oldblue
(Post 885905)
https://www.google.ca/search?q=hhr+a...&client=safari most are from the top, no need to lay on the ground. As I mentioned, the situation is this: I don’t want to lay on the ground, I don’t have access to a air tank, and I want to use the foaming cleaner to put in there as mentioned (Frost King Foaming Cleaner). So, given there parameters, I’m not seeing anything which fits this profile I have to work with. So I’m not reinventing the wheel, but more like working with a hoverboard. Lol 😁 |
This explains from the top. Sorry no pictures or mention of the foam stuff you want to use, most have said they used a tie wrap , or small hook to clear the hose
The foam stuff is administered from the inside outlet. I could reach down and tickle the drain from the top.
The problem is mold builds up in the tray and blocks the hose. So the foam dissolves the clog. |
Now that sounds doable!
