Alarm sounds, key won't turn
Old Jan 20, 2025 | 09:43 PM
Night's Avatar
I have a question about my HHR have you had a situation where you locked the vehicle by pressing the lock button after getting out. And then returning unlocking vehicle using the physical key unlock it and the alarm goes off and the anti theft goes off. But the ignition does not turn? And the Front wheel drive locks up.
Old Jan 21, 2025 | 07:45 AM
Yes, I have the battery was low on voltage
Old Jan 21, 2025 | 07:55 AM
Locking with fob turns the alarm on, opening with key sets it off. Normal behavior.
Key stuck in ignition is a sign of dead battery.
I don't know what "the Front wheel drive locks up" means.
Free digital Owner Manual link in my sig.
Old Jan 21, 2025 | 08:34 AM
Does "front wheel drive locks up" = "shifter won't move out of park"?
Old Jan 22, 2025 | 01:24 AM
Night's Avatar
Shifter will not go to neutral or move and the ignition tumbler will not turn with key .
Old Jan 22, 2025 | 06:36 AM
Check battery voltage, it. Should be 12.5 volts or higher
ggarmento
Maintenance and Upkeep
Jul 22, 2019 12:07 PM
GinaM
May 25, 2014 09:50 AM
eagle914
Jan 15, 2013 11:10 AM
R CA HHR
Sep 3, 2007 11:19 PM
mizzouHHR
Apr 12, 2007 07:22 AM
