Auto Shifter removal
As I push the button to shift out of park, the pin doesnt go past the brake interlock. At first the interlock wasnt working so some electronic spray cleaner made it work again. But the pin the button moves isnt going past the brake interlock. I have to manually push the pin down to shift out. Im trying to remove the shifter now but dont see how to disconnect cable from shifter.
Do i just pry it off??
Any help appreciated |
Yes. It just pops off, with a little prying.
Originally Posted by the_shmoo
(Post 682668)
I had the same issue and couldnt get anything down there to hold them either. Ended up taking the shifter apart from the top down. Talk about a PITA.
Once the side plastic panels are off insert a screwdriver thru the lower slots to hold the nuts. Also use the search for shifter repair. Hope this helps, it did for me. Lots off info on here from other members.
https://www.chevyhhr.net/forums/problems-service-repairs-42/shifter-repair-40183/ https://www.chevyhhr.net/forums/show...shifter+broken |
Dorman does have an affordable replacement rod kit.
But that does not address the interlock solenoid problem. The button on my 2011 is getting stuck when cold, but I hear clicking. It spent 3 nights at the Carmax shop, but of course, it worked fine for them. If it turns out to be the brake switch, they changed the part to a $65 part instead of the $15 on previous years. |
Originally Posted by donbrew
(Post 684909)
@hipHotRod, what did you have to replace to get this taken care of? My back yard mechanical mind is curious. LOL
Michelle, Chevrolet Customer Service |
@donbrew, with your vehicle being of the 2011 model year, this should be something covered under warranty unless your over the 36,000 mile mark.
