Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Car is a 2010 2.2. I was installing a new exhaust manifold, when coolant starting leaking from the back of the block on the right side. Is there a 13mm bolt back there that I could have somehow loosened to cause this. It’s a tight spot and will be able to take a closer look next week. Just curious if there is a bolt back there that I accidentally loosened. It’s going to be near a exhaust manifold stud.
Reason: Add something
I am pretty sure it is one of those bolts, especially if on of the is close to exhaust manifold bolt. Going to look at it in a couple of days. Thanks for your response and picture.
Hmm. Those water pump bolt/nuts don't even point in the same direction as the exhaust manifold studs. They are 90 degrees different in direction. Not sure how you could take off one of those even by mistake.
