Backup light issue
Old Aug 10, 2009 | 09:25 AM
indy8six's Avatar
Backup light issue
Hey all, new to the site.
I have an '07 HHR LS.. My problem is the backup lights quit working and I don't know why. The bulbs are fine and so is the fuse. Anyone know what could be wrong? Is there a relay and if so where is it? Thanks for any help.
Old Aug 10, 2009 | 01:28 PM
an08HHR's Avatar
Under hood fuse is #47. from there it (Pnk wire) goes to the Park/Neutral Position Switch (if it is a Automatic) or the Backup Lamp Switch (if manual Tranny) and then the wire (Lt Grn) goes to the left and right Back Up Lamps which are grounded with a Blk wire completing the circuit. No idea where the switch is located, someplace by the shifter most likely. NO RELAY.
Old Aug 10, 2009 | 03:01 PM
indy8six's Avatar
So does anyone know where the switch is located or a diagram that shows it?
Old Aug 10, 2009 | 03:48 PM
txbass06's Avatar
Is this what you're looking for?
Old Aug 10, 2009 | 04:40 PM
indy8six's Avatar
Thanks. that should help!!!!
Old Aug 10, 2009 | 08:11 PM
UncleDannie's Avatar
If not, use the ol' standby - hang your head out the window and turn on your flashlight. That will work as long as the batteries hold up and it ain't raining too hard.
Old Aug 11, 2009 | 09:11 AM
indy8six's Avatar
LOL....yea it's out of warranty, so if I can't fix it that will be the plan.
Thoughtninja
May 8, 2015 02:34 PM
Mak22492
Drivetrain (Excluding Engine)
Jan 20, 2015 11:09 AM
Lee3333
May 24, 2012 08:28 PM
racer-ray
Nov 29, 2010 06:38 PM
