Battery Drain
Old Jul 10, 2021 | 01:43 PM
Allen P's Avatar
Battery Drain
Hey,
My battery's been draining for the last two day when left parked and I think there's something draining it.
First off, I used a clamp meter to measure the current draw, should I be using it (because I felt like it was in accurate for low current values as its meant for higher loads)?
I checked for the voltage between the fuse terminal and ground, where I saw that there was a 12v reading between the fuse for INT light and ground. Is this normal?
The voltage between the two terminals is 12.9V
The voltage when the car is on is 14.6V
Thanks in advance,
Allen
Old Jul 10, 2021 | 08:50 PM
The light switches switch ground so, yes normal.
bursjon
Jan 20, 2017 10:09 AM
junker
Jul 26, 2016 10:16 AM
Snoopy
Maintenance and Upkeep
Oct 18, 2013 07:30 PM
jack burniston
Oct 6, 2013 07:17 PM
bluedograbbit2
Mar 26, 2013 07:04 PM
