Battery Draining Over Time?
Old Sep 20, 2014 | 02:29 PM
tucsondivots's Avatar
I replaced the battery in my 2010 HHR ten months ago. I began getting "service airbag and power steering" messages on my DIC when starting. I noticed this occurred most frequently when I did not drive the day before. Finally, after not driving for three days, the battery was totally dead. I took it back to Autzone (based on the suggestions from forum members) and they confirmed it to be a bad battery and replaced it under warranty in June of this year. In August I gave my HHR to my daughter. Today, after not driving yesterday, it would not start and had classic battery failure symptoms (cannot open hatch, key would not come out of ignition). They are taking the battery back to Autozone now to have it checked out. Could this be an alternator issue or something causing a voltage drain? I did not have the alternator checked in June because it was determined the battery was bad. Depending what they find out I will ask them to have Autozone check the charging system. I am just trying to understand what the issues might be, if it is not another bad battery.
Old Sep 20, 2014 | 03:13 PM
Could be a bad alternator or starter.
Has the throttle body been cleaned? That relevant because a bad or dirty or mis calibrated throttle position sensor can make the throttle seek for it's right position while the car is turned off, causing a battery drain. Not a huge probability, but possible.
Old Sep 20, 2014 | 09:09 PM
I am not sure but think that might have been done as part of 36K service? Quick update is both the battery and alternator checked out ok. My daughter said she did leave the hatch ajar a few days ago but shouldn't the battery protection feature have prevented a total drain?
Old Sep 20, 2014 | 09:11 PM
LawDog88's Avatar
Still rockin' the stock battery here...
Old Sep 20, 2014 | 09:38 PM
My battery can only stand about 15 minutes of headlights. It is good and the alt is good. They really suck at powering anything past the initial start.
Old Sep 21, 2014 | 01:33 AM
Thanks!
Old Sep 21, 2014 | 07:53 AM
Check for loose positive battery terminal under the hood and ground connection.
Old Sep 21, 2014 | 10:37 AM
Leaving the hatch or the doors open for even a few hours can cause problems if the dome lights are on. I left the doors open for 3 hours or so while removing a broken door handle - and on starting the car afterwards all the warning lights went kinda wild as it wore the battery down a bit.
Leaving the hatch open would be my suspect.
Old Sep 21, 2014 | 02:13 PM
Thanks. That sounds like what happened.
Old Sep 21, 2014 | 04:02 PM
Hmmm. The interior lights on my 2010 will shut off after about 15 mins. if the doors are left open.
You guys don't have that "time out" protection system on your HHR's ?
