Blue Tooth drops out after programming
Old Sep 9, 2019 | 12:43 PM
Cat Man HHR's Avatar
Don't know if this should be here, move it if need be.
I noticed now that the phone that is paired with the car doesn't work with Blue Tooth.
This happen once before and I found on a Cobalt forum to pull fuse #24 inside the car to reset XM radio and On Star.
That trick worked but the problem came back. Don't know how long cause I normally don't carry my phone with me.
It has now happened again, reset Blue Tooth on my phone, pulled #24 fuse, paired phone to car and it worked.
It has now dropped out again even though the phone is paired.
Am I looking at a possible Tech Two solution to this ?
Or a software update from the dealer ?
Old Sep 9, 2019 | 06:01 PM
It could just need a complete reset, you know the drill, battery lobotomy. A full 30 minutes disconnect the negative terminal at the battery.
I like to try the easy peasy stuff , first.
At least it’s no cost and most times effective.
Old Sep 10, 2019 | 04:13 AM
Just as a test I'll try it.
Old Sep 10, 2019 | 06:58 AM
Fingers crossed ,
Old Sep 10, 2019 | 07:51 AM
I did find some info regarding the On Star module in the back of the car that is connect to the Blue Tooth system.
I wonder if this might be cause of my problem. No way to test it though.
I guess by doing the R&I of fuse #24 you are resetting the On Star module.
Also I don't have an On Star subscription active.
Old Sep 10, 2019 | 12:43 PM
Subscription should not matter, but the fuse does. Remember the tiny antenna is buried back there too.
Old Sep 11, 2019 | 05:04 AM
Could you explain that ?
I have the shark fin on the roof.
Do you mean the wire that goes to it ?
Old Sep 11, 2019 | 08:41 AM
The BT antenna is tiny and buried in the box and in your phone. BT is radio subject to interference. The frequency is 2.45 GHz.
Old Sep 11, 2019 | 11:06 AM
OK .So how do you prove your information ?
It doesn't matter where I am. Towers are very well placed around me.
Long Island is flat. Lol.
Old Sep 11, 2019 | 11:54 AM
BT and getting your phone signal from a tower..........2 different things. Shark fin on the roof. Nothing to do with the BT.
Someone isn't clear on what "system" you are talking about.
