Brake lights
Old Apr 3, 2011 | 11:12 AM
BlackknighT's Avatar
The brake light switch assembly is only energized with key on. It is also incorporated into the cruise control-hence only works with the switch on....
Old Apr 4, 2011 | 01:51 AM
Not all HHRs' have cruise conrol.. Mine does, but many do not..
Old Apr 4, 2011 | 09:17 AM
MaryJane's Avatar
Mine does :)
Old Apr 4, 2011 | 11:02 AM
prod's Avatar
Huh? Where did you see that, its standard on every HHR AFAIK.
Old Apr 4, 2011 | 11:17 AM
All still have the same type brake light switch set up....
Old Apr 4, 2011 | 11:19 PM
prod-
I believe you are correct.. I stand corrected. Thanks for pointing that out.
I had Onstar* in my head, which is an option..
Old Apr 5, 2011 | 12:46 AM
prod's Avatar
Yeah, the onstar is tricky, as I bought my 08 it was standard (in Canada), not before though, not sure about after.
Old Apr 5, 2011 | 12:49 AM
A friend in the US has an 09 2LT that came without Onstar* It has this code in the build sheet:
UE0 - DELETE ONSTAR/BLUETOOTH FOR PHONE
Old Apr 5, 2011 | 11:44 AM
MaryJane's Avatar
can you get onstar added on later if you wanted to? how hard would that be?
Old Apr 5, 2011 | 11:15 PM
Good question, IDK ?
