Brakes
If so that could be just surface rust on the rotors.
Did you look to see the pads are OK ?
Does the car pull to one side or the other when it happens ?
When did this noise start ?
You can lube the metal tabs on either end of the brake pads , I have seen the SS pad retainers rub the rotors and cause noises.
I have also seen the brake caliper brackets installed on the wrong sides, they are left only, right only specific , it causes the pads to wear unevenly.
