Buzzing vibrating sound
When driving at faster speeds going around corners and Bends it has a weird sound like a buzz vibrating not a clunking 2006 LT
but when going straight it's quiet just when I'm turning left or right around Big bends not sharp corners |
Probably hubs/bearings, maybe worn out brake pads or LCA bushings.
I replace the lower ball joints, brake pads look good and I replaced sway bar end links.
tomorrow I'm going to install control arm bushings |
2008 hhr
I have a similar but different issue I have a constant vibrating faster I go the worse it gets I jacked up the car and let the wheels spin freely the driver side binds up and stop spinning the passenger side makes a small ticking sound but it does not stop spinning
Oversized tires? If so, what size?
