A/C Compressor Not Running
Old Jul 31, 2018 | 01:49 PM
cyberwolf009's Avatar
All my tests were leaning toward the compressor being the culprit, but I took it to a shop to be sure. It is the compressor clutch and they quoted $1400 for the compressor, expansion valve and labor. So I guess I am going to tackle this job. One more question - is there any harm in having the system evacuated up to a week before actually opening the system? I'm ready to order a compressor, but might as well have them evacuate the freon while it's at the shop.
Old Jul 31, 2018 | 02:33 PM
Kits are available
https://www.rockauto.com/en/catalog/...nent+kit,17507
and we get a discount from RockAuto
https://www.chevyhhr.net/forums/supp...-2018-a-60583/
now log log in and search for your specific year and engine
Old Jul 31, 2018 | 02:41 PM
Wow, thanks for that! I was already looking at Rockauto, but not at the kits. They are a good deal. Any recommendations between the different kits?
Old Jul 31, 2018 | 02:57 PM
Never used or installed one, so I can’t say.
However I’m sure someone here has experience with A/C repairs
Old Aug 1, 2018 | 05:41 PM
Blue_SS's Avatar
Don't pull a vacuum that far in advance. You will have some seepage, even in a new system. Do it right before refill.
Old Aug 2, 2018 | 05:00 PM
tiapetra's Avatar
It sounds like he is just having the refrigerant removed legally so he can work on it.
If the same shop is going to do the charge when he's done, then I'm sure they would be more than happy to put a small charge of nitrogen in it for him since it costs almost nothing.
He should replace the drier anyway, and flush every component, so having the system closed off but neutral is really not of much concern.
Old Aug 3, 2018 | 06:18 AM
Yep, that's exactly the scenario. System is drained, but closed and parts are arriving today.
Old Aug 3, 2018 | 07:18 AM
Cat Man HHR's Avatar
Change parts and then go back to repair shop for the proper evacuation and charge. Are you adding oil to the compressor and dryer before the install? You don't have to flush the system, no hard core failure happened.
Old Aug 3, 2018 | 07:31 AM
Yes. I'll be adding oil as specified and I will be replacing the condenser/receiver dryer and expansion valves.
Old Aug 3, 2018 | 07:37 AM
We’ll need pictures!!!
