A/C and Heat Air Flow **VERY WEAK**
Old Aug 21, 2007 | 02:49 AM
chitownbro1's Avatar
Angry A/C and Heat Air Flow **VERY WEAK**
I drive down to the city, about an hour drive, park 30 minutes late get back in and my A/C doesn't come out at all. So i put it on full blast and barely anything comes out. I tried all the different outlets and heat as well, but still weak air flow. When I accelerate, the air flow picks up but doesn't stay strong. It's almost like the car can't create it's own air flow for the A/C and Heat. Please someone give me an idea????
Old Aug 21, 2007 | 03:16 AM
tcstoy's Avatar
First thing I would check would be the fuses. If they are good, I would then check the blower motor. Possibly check the cabin filter and see if there might be some sort of obstruction in that area. If it is still under warranty........let the dealer trouble shoot the problem.
Old Aug 21, 2007 | 06:28 AM
GCarp's Avatar
Does it sound like the blower is spinning up when you adjust it from low to high? If the doors in the ductwork arent moving, and the blower is on, you should hear a lot of noise when the air doesn't have a place to go... Either way it sounds like its time for a dealer run...
Old Aug 21, 2007 | 03:19 PM
Alzonie's Avatar
Maybe there's an old Bean Burrito stuck in an air duct somewhere!!
Old Aug 21, 2007 | 03:49 PM
Skyman's Avatar
First If the Blower is working I would pull out the Cabin air filter located behind the Glovebox the turn on the fan and see what happens.... there could be an obstruction before the air filter... or in the air filter.
Old Aug 22, 2007 | 06:05 PM
Brewer13's Avatar
Yeah, I have the problem where the only fan speed that works is the highest.
Old Aug 22, 2007 | 06:20 PM
HHRAZ's Avatar
I live in AZ and I have to say that the A/C works really well. I have an Avalanche, that is in the shop, and I think the HHR has a better setup
Old Aug 23, 2007 | 01:38 AM
no matter what speed its on it still doesn't blow any different. Yeah, i'll just bring it in tomorrow and let the bastards over at Chevy deal with it.
Old Aug 23, 2007 | 10:53 AM
Hellraisehr's Avatar
Resistor
sounds like a blower motor resistor.
Last edited by Hellraisehr; Aug 23, 2007 at 10:54 AM. Reason: Yeah, I have the problem where the only fan speed that works is the highest.
Old Aug 25, 2007 | 11:06 AM
cc732's Avatar
i agree with hellraisehr....the blower motor resistor is shorted.
When I had a waterleak on the passenger floor, the blower got wet and would only run on high.
Clare
