A/C Issue
There is circulation air that comes through the air vents when the car is moving. It stops flowing when the car stops. It is not produced by the blower fan.
Maybe that is the air flow you're losing?
Check to make sure your blower fan and motor are actually working. The air flow you have now may just be that circulation air from the outside mixed with the AC cold output.
That's actually backwards. If the system was low on charge but still had enough to engage the compressor at idle, the low side pressure would drop as engine rpm increased causing the compressor to disengage when that pressure became too low and engage again when the vehicle returnes to idle.
According to his post the OP is apparently losing the A/C at idle, then regaining it at speed, but we do need more info.
Admittedly my knowledge of automotive HVAC is a bit out of date since my days of servicing systems at a Firestone store ended in the late 80's. We used the following list for a "no cold air" or "loses the air" complaints.
Customer Complaint...Insufficient Cool Air
Check For...
Low refrigerant charge
Loose drive belt
Slipping compressor clutch
Clogged condenser
Clogged evaporator
Slow leak in system
Partially clogged filter or expansion valve
Hopefully we'll get more details from the OP soon.
Check For...
Loose drive belt
Clogged condenser
Clogged evaporator
Slow leak in system
What's a little confusing is that he says 'stops blowing' and 'starts blowing again'. Not sure if he means blowing cold or blowing period. Need more info. If he's losing the airflow that wouldn't have anything to do with refrigerant.
I read it to mean that the blower fan was not working correctly, or at all. Hopefully the OP will come back and post up some more precise details.
dont mean to jack the thread..but whats the difference between having the AC on and having the inside air circulate at cold temp..if i select the inside circulation, the compressor turns on as well..so whats the purpose of having both?
I believe the concept of recirculate is to produce a desired result when directed at female passengers on those really hot days, then again I may be misusing the control.
