A/C problem with 2006 HHR
Has any had the following problem with their HHR? The A/C would only work on high and then it stopped working. I changed the blower fuse on the inside fuse panel but still it does not work. Any other ideas or suggestions?
Thank you |
Originally Posted by cepillo
(Post 305104)
Originally Posted by Latrevion.washington
(Post 305108)
yea...TAKE IT TO THE DEALER!
had a chrysler cirrus that had the same problem. i had to change the reistat(resistor) and that worked for the blower for 2 days then only on high again. talked to mechanic and was told blower motor was bad causing this resistor to pop. changed blower motor and new resistor and no more problem.
If you had the water leak problem that 06's and 07's had, water shorted the blower motor resistor which is 25 to 50 bucks depending where you buy it. It is up under the pass side by left of the blower motor right by the firewall. Not too hard to change if you are handy
Is the A/C comp coming on? With key on, eng. not running can you hear the A/C clutch click when you push the A/C botton on & off?
If yes then blower switch or the reistat(resistor) like HHRse said. Also #30 relay in the floor console fuse block |
IMHO....
See post number 5 and 6 for good trouble shooting answers !!!:D |
Originally Posted by an08HHR
(Post 305134)
Thank You
Thanks for your input. sure enough the blower and resistor out. dealer wanted 800 dollars. i'll take it to another mechanic.
Originally Posted by HHRse
(Post 305116)
Make sure whoever does the repair checks for water leaks... It'll probably happen again if there's a water leak. (Search for butyl patch repair on this site)
