Chevy HHR Network
-   -   A/C problem (https://www.chevyhhr.net/forums/problems-service-repairs-42/c-problem-30921/)
06SILVERLT Jul 28, 2010 07:31 AM
A/C problem
the a/c still continues to run after i push the little snowflake for it to go off
ChevyMgr Jul 28, 2010 07:49 AM
Is it set to recirculate?
06SILVERLT Jul 28, 2010 09:52 AM
yes it is and after i push button to turn a/c off but leave air on it still blows ice cold air and no the defrost isnt on either
Greybeard999 Jul 28, 2010 12:03 PM
It should blow cold for a several minutes after shutting off the AC, that's normal. Does the yellow light go off when you push the button?
ChevyMgr Jul 28, 2010 12:07 PM
A/C will run if recirculate is selected. Doesn't matter what the lights are doing, as long as it is switched to recirculate or defrost the compressor will be running.
goetylsd Jul 28, 2010 12:12 PM
So, if I turn my car to "recirculate" every time I go somewhere, it's like I'm always running the air conditioning then?
ChevyMgr Jul 28, 2010 12:25 PM
Yes.
goetylsd Jul 28, 2010 03:46 PM
Oh, that sucks. I thought by running it on recirculate (which is actually really cold) instead of air conditioning, I was saving gas. Oh well, I guess I need air conditioning either way then.
Laco Jul 28, 2010 04:22 PM
Just don't run it on recirculate, let it draw in outside air, then you can turn the compressor off, and only use outside air to vent, at least if its cool enough outside to do so.
06SILVERLT Jul 29, 2010 11:10 AM
well i have to head out shortly and i'll try what you said and see if it makes a difference i'll be on after 3pm thanks
