Can changing auto transmission fluid in your hhr actually do harm??
Old Mar 31, 2026 | 12:07 PM
Ericwest11's Avatar
I want to change the fluid as the car has 125k on it ...but a guy working at a gm wrecking yard told me that changing all the fluid can actually cause the transmission to start slipping and he said change only half the fluid! But that's not easy to do if I have to drop the pan....there is no drain plug right? Catching the fluid and keeping it clean seems tough ..I know the tongue converter holds some fluid maybe it holds enough for a change of fluid in the pan to be 50% of the total fluid?? Any advice would be appreciated
Old Mar 31, 2026 | 12:16 PM
lazaino's Avatar
I think he's messing with you! There is no way to change 1/2 the fluid. Ours has been changed twice with no ill effects.
Old Mar 31, 2026 | 05:18 PM
Changing is fine it is back flushing that is bad.
When you drop the pan you only change the fluid that is in the gearbox, you can't drain the torque converter. That is a quart or 2.
Waynejwj
Mar 17, 2024 05:30 PM
MJR1970
Maintenance and Upkeep
Feb 26, 2023 09:40 PM
ScareDe2
44
Jun 15, 2022 08:44 AM
Gearhead1
Oct 25, 2021 08:15 AM
Herbie
66
Jul 7, 2014 10:52 AM
