Cant' shift out of Park.
I tried using the search function, but it doesn't seem to be working for me. I click on it, and nothing happens, so sorry if this issue has already been covered:
I've only had my 2007 for 4 months, I put 9000+ kms on it in this time (long commute to work). So far has never given me any problems whatsoever, but two days in a row now, after I start it in the morning, I can't shift it out of Park.
I swear, I rant, I rave, I keep trying and trying. I get out of the car and rock the car back and forth (don't ask me why, just something to try . . . ), and try again.
I rev the car and CLICK! it shifted! Yeah!!!
Same scenario this morning, same brillant and highly technical trouble-shooting series of behaviour from my part, but this time the rev-ing of the engine didn't do anything. BUT!! after reving to no avail, I stomp on the brake, and CLICK! we are in Drive!!
Any idea why I'm having this problem? Thanks for your help!
It`s probably it`s the switch on the brake pedal that`s bad.
You must put on the brake to shift out of park, and the switch isn`t sending the signal.
Try starting out in neutral, I don`t think the switch is required if you`re already out of park, you should be able to go to neutral and start.
I had the same problem in January. Had to have it towed to the dealer. The Dealer had to replace the shifter mechansim. Luckily it was under warranty, even had a free rental due to the timing/parts delays (New Years weekend).
I know it may seem like this may to simple of a solution, but, make sure you are applying pressure on the brake pedal before grabbing the shifter.
I sometimes catch myself trying to shift before I step on the brake pedal, and the shifter won't move until I just start from scratch again remembering the advice above.
Yep...Sorry
Sorry, brain fade, thinking about older cars, please forgive me...
