car loading up. wont even stay running
hey guys, wondering if someone can help me out. my 08 hhr ss loading up so bad it wont even stay running. changed the maf sensor and still the same. anyone else have or had this problem and fixed it. I would appericate the know how to fix
Is the CheckEngineLight on? What codes.
You gotta give us something to work with. I don't know what YOU mean by "loading up". |
its not throwing codes atm but when it did. I believe it was po114. loading up means its getting way to much gas. I think it is the camshaft sensors opr whatever they are
That P0114 is a clue
Faulty MAF sensor Clogged air filter Broken intake air inlet pipe Read more at: https://www.obd-codes.com/p0114 Copyright OBD-Codes.com Per https://www.obd-codes.com/p0114 |
checked all that. had intake off, replaced the maf and replaced the air filter and still is doing the same
If it was running rich you would have a CEL. What makes you think it is "getting way to much gas"?
Originally Posted by Eric Overmiller
(Post 837879)
Is the temperature gauge reading normal? |
