car loading up. wont even stay running
Old Feb 5, 2018 | 02:23 PM
Eric Overmiller's Avatar
hey guys, wondering if someone can help me out. my 08 hhr ss loading up so bad it wont even stay running. changed the maf sensor and still the same. anyone else have or had this problem and fixed it. I would appericate the know how to fix
Old Feb 5, 2018 | 02:53 PM
Is the CheckEngineLight on? What codes.
You gotta give us something to work with. I don't know what YOU mean by "loading up".
Old Feb 5, 2018 | 03:02 PM
its not throwing codes atm but when it did. I believe it was po114. loading up means its getting way to much gas. I think it is the camshaft sensors opr whatever they are
Old Feb 5, 2018 | 04:03 PM
That P0114 is a clue
Faulty MAF sensor Clogged air filter Broken intake air inlet pipe
Read more at: https://www.obd-codes.com/p0114
Copyright OBD-Codes.com
Per
Old Feb 5, 2018 | 04:07 PM
checked all that. had intake off, replaced the maf and replaced the air filter and still is doing the same
Old Feb 5, 2018 | 07:08 PM
Check the air/intake charge temperature sensor?
RockAuto
Old Feb 5, 2018 | 10:03 PM
If it was running rich you would have a CEL. What makes you think it is "getting way to much gas"?
Old Feb 6, 2018 | 03:23 AM
Cat Man HHR's Avatar
Is it blowing black smoke out the exhaust?
Is the temperature gauge reading normal?
RJ_RS_SS_350
Feb 7, 2016 10:48 AM
fuzzysig
Dec 8, 2015 07:29 PM
kenny240
Apr 2, 2015 03:32 PM
urbexHHR
Apr 24, 2011 09:58 PM
AZ RADIO
Jan 2, 2007 04:36 PM
