Car won't start
Old Dec 6, 2020 | 11:39 AM
19camaro69's Avatar
Sorry for the slow response, I work a late shift. All fuses are good. The factory wires that I do not have connected are the white/black, violet, green/white and the pink. On the radio side I do not have the reverse " no backup camera " or the rem out cable. The battery did go dead on me and I did make a little spark which popped fuse 8 when I had to cut everything loose due to the fact that the first radio I got would not fit without a lot of cutting. The one I have now is a sony
Old Dec 6, 2020 | 12:12 PM
So you have a dead battery. Problem solved. Charge it up or get a new one.
Old Dec 6, 2020 | 12:54 PM
19camaro69's Avatar
Yeah I did that when I realized it was dead, charged it and the battery is holding a charge
Old Dec 6, 2020 | 01:04 PM
You fried something with the first radio installation. Fuse #8 is ignition and passkey 3.
Have the ignition related recalls been performed?
Old Dec 6, 2020 | 01:53 PM
19camaro69's Avatar
No for sure if the recall has been done I've had the vehicle for a month now
Old Dec 6, 2020 | 02:02 PM
19camaro69's Avatar
Just looked it up on the nhtsa site and it says all repairs have been done
Old Dec 6, 2020 | 05:36 PM
Unclear if it is fixed now. If not, fuse #8 is the ignition switch, figure out how you managed to blow it then fix whatever did it. Sounds like someone was looking for a switched circuit.
I don't know how you could have blown it doing a radio install.
Old Dec 6, 2020 | 05:58 PM
19camaro69's Avatar
Never trip fuse 8i misquoted earlier, I blew fuse 23, and car is still dead
Old Dec 6, 2020 | 06:00 PM
19camaro69's Avatar
Sorry for the confusion
Old Dec 6, 2020 | 06:45 PM
I don't see a violet wire (maybe one of the dk blu wires, one is steering wheel controls the other is RR speaker). The pink goes to the antenna amp (if you want to listen to radio with the factory antenna it is needed) and is the on signal for a amplifier. The blk/wht is ground. the wht/blk is 10 volt ref(for steering wheel controls).
The dk grn/wht wire is the computer data line.
I still can't think of anything a plain radio transplant could cause a no crank.
