CEL and P0011 code on 2011 LT
So this happened yesterday on the way home from breakfast.
No symptoms, just the light and then I checked with the OBD Bluetooth dongle.
a search brought this thread up.
https://www.chevyhhr.net/forums/how-...13-14-a-28779/
Would it be this part if there's no symptoms? Oil life is at 18% but it was low earlier this week so I added a quart.
(So yeah, for those keeping track, we're driving the 2008 with the coolant leak now.)
What symptom would you expect, other than the computer telling you the exact fault?
I would suggest replacing both at the same time to save some time.
When dirty oil is involved we are talking filthy oil not nearly due for a change oil. The VVT valves have very fine screens on them that can get clogged causing the code, or something internal goes bad.
What oil are you using? Using a quart in 9,000 miles is a little unusual. Should be 5W30 with a DEXOS label. I found that Mobil 1 burns more than others.
P0011 means the ECM thinks the VVT intake cam isn't going where it's commanded to go. This could be a malfunctioning phaser, but is almost always a malfunctioning valve section in the VVT intake solenoid valve assembly. If you pull it out you may find junk clogging the screen, but the problem could be inside.
This is a case where in make sense to replace both the intake and exhaust solenoid valves, because the underlying cause is usually deferred oil changes.
If it were my car, I would:
CEL should eventually go out on its own. Or you could clear it, and if you solved the problem, it won't come back.
Re: the oil consumption, I would do a compression check.
How many miles on the car? Not that it's terribly relevant, just curious, 2.2 or 2.4?
- Immediately add 1/2 quart of ATF or seafoam to the oil. After about 50 miles, change the oil, using any well-known brand of 5-30 Dexos full-synthetic. Do NOT use "high mileage" oil now or ever again.
- Once the oil is changed, replace both solenoid valves. Use the latest OEM or AC Delco superseding p/n.
- Never go beyond 50% oil life on the DIC. Too many things can go wrong in these engine with gunky oil.
