Center Brake Light stay on?
I dont know if I missing some other have same.
My HHR was battery dead and replace new battery and found Center Brake Light stay on cause it. I unplug to save the battery. How can I repair that problem. I cannot find where switch from center brake light?
Are you sure that the other brake lights are not stuck on while driving?
The switch is the same, however I think the side lights go off when the key is off.
From your Owner Manual there is this:
It could be stuck.
Fuse #9 on the inside fuse box is for the stop lamps.
There is a link in my sig for online Owner Manuals.
It could be stuck.
I searched and found
https://www.chevyhhr.net/forums/prob...removed-26501/
In there this was recommended for the brake switch
https://www.chevyhhr.net/forums/prob...-lights-26379/
Read the post #12 and change out the switch
LED bulbs can cause a couple of problems with circuits that were not designed for them. They can light up from bleed through current, they can "latch" on, they can provide a new route to + via G probably more.
It looks like '06-'07 had 2 actual 'switches', even the automatics. Some are no longer available. For the stop lamp switch, P/N 12450036 Seems the other switch has to do with the trans.
Starting in '08 it went to a single 'sensor'. P/N 15192340 All trim levels, 1 sensor for brake, same part number for clutch sensor, if applicable.
The information below seems to pertain to the '06-'07 clutch pedal switches, although GM calls one of them a stop lamp switch
No longer available P/N 22620888 '06-'07 HHR Manual trans stop lamp switch, VEHICLES BUILT ON 10/29/06 AND PRIOR .
A little confusing here, the drawing shows it and another switch, both on the clutch pedal, nothing on the brake pedal. But a different drawing shows 2 switches on the brake and none on the clutch. The 2 drawings must go together. '06-'07 has 2 switches on brake pedal and 2 switches on clutch pedal. Can anyone confirm?
VEHICLES BUILT ON 10/30/06 AND AFTER P/N 25800562 this time they're not calling it a stop lamp switch. So I think P/N 22620888(above) is not actually for the stop lamps.
My search was for 'brake pedal' http://www.wholesalegmpartsonline.co...=brake%20pedal
