Change in MPG
Old Jul 4, 2017 | 09:24 AM
Did you get the right plugs or the ones the counterman said to get? AC/Delco 41-103.
What is the coolant temp doing? You are sort of describing overheating.
Old Jul 4, 2017 | 02:39 PM
chessplayer41's Avatar
The plugs are platinum and the coolant is now under 197 but looks like I found the culprit. I knew I was hearing an exhaust leak even after replacing the CATs so I figured maybe the bolts were not tightened or maybe another gasket is needed but I found A fracture in the exhaust pipe. I put another one on and my car is back running quiet and smooth. The MPG is slowly going up so hopefully I get back to the 29-31 MPG as before.
Old Jul 4, 2017 | 03:00 PM
Ecotec 's don't like platinum plugs they are designed and built for iridium plugs, AC Delco as Don pointed out
Old Jul 4, 2017 | 03:02 PM
Wrong plugs! 41-103 are Iridium and will last at least 100,000 miles and the engine is built for them.
But we were wrong about the flex pipe, too.
Creole Dude
Jul 28, 2016 08:46 PM
JWA
16
Jun 21, 2014 12:16 PM
badassbowtie
Maintenance and Upkeep
23
May 12, 2013 02:01 PM
Mr_goodtool
Jun 9, 2007 12:51 PM
SoCalHHR
Dec 2, 2005 06:40 PM
