Chevy HHR LT 09 Service ESC/Traction
Old May 3, 2021 | 05:13 PM
Car is running , parking brake is set
Old May 3, 2021 | 06:57 PM
At a stop light.
Old May 3, 2021 | 07:00 PM
Probably an automatic transmission. If so, no reason for the parking brake to be on in this situation.
Old May 3, 2021 | 07:05 PM
In my 2LT, the word brake illuminates when you engage the parking brake
Old May 3, 2021 | 08:01 PM
Carlos Xavier Rios's Avatar
The car has no flat tires. And the brake lights always come up when the Service ESC/Traction pops up (even if the brake is down).
I’ll be buying some of the new sensors to see if it’s that first and install them. I’ll come back with an update in a few.
Old May 3, 2021 | 09:42 PM
Then why is the TPMS light on? So this is not new? The fact that the brake light is on means that the problem is in the brakes NOT the ABS or ESC systems or the typical engine problems.
In other words; there is something unusual going on not the typical.
While the ABS light is on a scanner that is capable of ABS can retrieve the codes. They don't store in memory.
Old May 4, 2021 | 07:04 AM
Carlos, which sensors will you be buying ?
Old May 4, 2021 | 02:58 PM
The one that warns you about brakes and such.
Old May 4, 2021 | 04:17 PM
(I think I can hear Don's brain exploding......................................... ................... )
Old May 4, 2021 | 06:01 PM
Lonwane's Avatar
And I'm not cleaning that up
