Chevy hhr shut off and wont start!
Old Nov 23, 2018 | 10:55 AM
theblakeh's Avatar
Question Chevy hhr shut off and wont start!
My wifes chevy hhr died going down the road and now I cant get it to start at all, it will turn over fine, new plugs, new throttle body, new pedal(with position sensor) new reman alternator(under warranty), showed a P0122 code but doesn't show any codes now! car is a 2006 hhr 2.2L automatic 240000 miles!
Old Nov 23, 2018 | 11:06 AM
My guess is the timing chain broke. Pretty simple fpr a mechanic to diagnose.
Old Nov 23, 2018 | 11:52 AM
More details and clarification please - did you replace all those parts before or after it died on you? If it is a timing chain like donbrew suspects, the engine might well be a write off. Was there any rattling or weird noises from the engine before it died?
Old Nov 23, 2018 | 12:44 PM
theblakeh's Avatar
these were put on after the car died, per a mechanics recommendation, (seems like now he was just guessing) and is there any way to check the timing chain without a true mechanic looking at it?
Old Nov 23, 2018 | 02:52 PM
theblakeh's Avatar
and no weird rattling noises or anything
Old Nov 23, 2018 | 03:38 PM
If you can take the cam cover off the top of the motor and observe; if you see gears and no chain: broken, if the chain has noticeable slack: broken, if it does not move when the starter is cranking: broken.
If this guy didn't do that simple test threaten to sue him. He may have fixed the P0122 but there is no way of telling if the motor is not running, I doubt it.
I don't suggest going to a Dealership, they went to the same clown school this guy did.
Old Nov 23, 2018 | 04:45 PM
If you pull the valve or cam cover, and it’s this loose, it’s the timing chain.
Old Nov 25, 2018 | 11:13 AM
theblakeh's Avatar
This is what it looked like when I pulled valve cover, when I spun. The crank it became loose
Old Nov 25, 2018 | 11:25 AM
theblakeh's Avatar
Old Nov 25, 2018 | 12:06 PM
How did you spin the crankshaft? By turning the key to start? Or by hand, with a socket and ratchet? If by hand, clockwise or counterclockwise?
