clunking sound when shifting
Old Jun 4, 2013 | 05:27 PM
skyline26's Avatar
08, auto, 76,000kms or 47,000miles..i hear this clicking/clunking sound when i shift out of Park to any gear P R D, hear it through all of them...there was never a noise before but im just wondering if this is normal? maybe tranny fluid needs changing?
Old Jun 4, 2013 | 05:35 PM
ATF would not cause anything like that.
Before what? You have done lots of modding, many that could cause the clunk. Exhaust pipes, motor mounts, trans mounts, there is a bracket between the trans and the engine, could be CV/axles, could be struts/springs/mounts, forgetting to tighten a bolt or 2.
Old Jun 4, 2013 | 05:39 PM
skyline26's Avatar
i have done exhaust work but i cant see that making a clunking sound as i switch through the gears standing still
Old Jun 4, 2013 | 05:44 PM
The engine moves when the gears switch, thusly moving the exhaust system around. That's why I included mounts.
Old Jun 4, 2013 | 05:46 PM
skyline26's Avatar
so your saying mounts are going?
Old Jun 4, 2013 | 05:49 PM
First thing. You need to find precisely where the noise is located.
With a helper, one of you place it in and out of gear while the other locates the area where the noise is. Get back here when you have a better location narrowed down.
A broad guess. If you've changed or altered the exhaust, it could be hitting something when the engine torques or moves within the engine mounts.
Old Jun 4, 2013 | 06:38 PM
B.Diggity's Avatar
Does it clank when ur car shifts gears?
If not, then id assume its a tranny issue. Mounts could be, but do some hard pulls, if no noise, i couldnt see it being the mounts, but i could be wrong. If u have a dipstick check it and see if it smells burnt or looks foul.
Old Jun 4, 2013 | 06:46 PM
skyline26's Avatar
im noticing it now with the warmer weather out and plus i did exhaust work but everything bolted up fine and firm no fitment issues...but i gota look into it more deeply..
its automatic so when im going thur p r n d i l it clanks on everyone one of them
Old Jun 20, 2013 | 04:23 PM
skyline26's Avatar
still have the sound..and the mounts checked out to be fine still...im now worried its the tranny..aaannddd i think my drivetrain warranty just ended lol yay
Old Jun 20, 2013 | 05:04 PM
OK, the mounts appear to be fine. What about the other suggestions? We can't help you, if you don't help us with some info.
