Codes P0011 and C0561
Old Dec 4, 2010 | 04:39 PM
DaveB's Avatar
This problem has occurred twice in the past two weeks, each time on extremely wet roads and after I’ve driven several miles. The T/C light illuminates and the following codes are set:
P0011 - "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
C0561 - System Disabled Information Stored
There seems to be reduced power and definite hard shifting each time this happens. The codes reset ok and the car drives normal after.
I've read about P0011 elsewhere on this forum but not in conjunction with the ABS code. I haven’t had this happen on dry roads yet which makes me think something is getting wet!?
Anyone had similar experience?
Old Oct 31, 2013 | 02:52 PM
1hotlava1's Avatar
p0011
saw the post about replacing the solenoid for a code p0011. i did that and it seems to run smoother. the problem is the check engine light comes back on and now i have the service esc and service traction message. i did recently have rims put on and i don have the sensors put on yet. what could be the issue with the check engine light on? i replaced the intake solenoid...
Old Oct 31, 2013 | 05:18 PM
What is the code being generated by the CEL now? Any suggestions would be a guess without that code.
what "sensors" are you referring to?
imcrzy8
Aug 5, 2015 08:49 AM
mpc3227
Maintenance and Upkeep
Jul 13, 2015 07:03 AM
papa_jo
Apr 28, 2015 03:54 PM
Nenda
Oct 23, 2014 10:01 PM
Tikker
Apr 9, 2010 07:18 PM
