Codes P0131, P0171, P0300 & P1133
for the techs out there, can all these be caused by a bad oxygen sensor?
Or a blown EXH fuse #33 under hood.
Nope, not it. Fuse looks fine. 😔 |
But did they test fine? Check them with a multi meter |
I'll try an different fuse after work.
Could be the wire/connectors to #1 sensor or the sensor.
I am going to start with replacing the upstream sensor. Think it’s worth it to buy/rent the socket or just cut the wires & use a standard socket to remove it? |
The socket won’t squeeze into the space , use a 7/8 wrench |
