Codes P0131, P0171, P0300 & P1133
Old Mar 18, 2019 | 06:03 PM
rbunton's Avatar
for the techs out there, can all these be caused by a bad oxygen sensor?
Old Mar 18, 2019 | 06:26 PM
Or a blown EXH fuse #33 under hood.
Old Mar 19, 2019 | 05:03 AM
rbunton's Avatar
Nope, not it. Fuse looks fine. 😔
Old Mar 19, 2019 | 09:47 AM
But did they test fine? Check them with a multi meter
Old Mar 19, 2019 | 01:16 PM
rbunton's Avatar
I'll try an different fuse after work.
Old Mar 19, 2019 | 02:38 PM
Could be the wire/connectors to #1 sensor or the sensor.
Old Mar 19, 2019 | 07:40 PM
rbunton's Avatar
I am going to start with replacing the upstream sensor. Think it’s worth it to buy/rent the socket or just cut the wires & use a standard socket to remove it?
Old Mar 19, 2019 | 08:08 PM
The socket won’t squeeze into the space , use a 7/8 wrench
ducter
Oct 17, 2014 07:35 AM
soundskillet
Jan 4, 2014 10:17 PM
swangelica
Aug 7, 2012 04:42 PM
Logrus9
Jun 15, 2011 01:52 PM
Tikker
Apr 9, 2010 07:18 PM
