Collapsed Lifter?
Old Dec 27, 2009 | 10:18 AM
urbexHHR's Avatar
Originally Posted by masterchief1112
the ecotec has very loud injectors because they operate at over 50 psi, makes them a little noisy, also the motors will have loud valve chatter when the engine is started when its cold and the valve train is waiting for oil on the startup.
And that could be too, since I've never owned the HHR when it was very cold... I bought it in February, but we had an early spring...
Old Dec 27, 2009 | 10:59 AM
Laco's Avatar
If you are running the correct oil, IE: 5W-30 or even 0W-30, there should be virtually no wait for oil to get to the top end. Noisy lifters, or followers are not the norm, even in cold weather. Any unusual noise or sound is trying to tell you something about the state of the engine, which may or may not be serious. In your case, it could be as simple, as it has just been sitting for a long time, and will resolve, with that 'gentle' test drive. Until you do that, everyone is just guessing at the problem.
Heritage High Roof
Maintenance and Upkeep
46
Jan 3, 2015 12:30 PM
deluxreverb
Nov 14, 2014 03:18 PM
JeramieJJ
Apr 22, 2009 04:47 PM
