Compression numbers - HELP
Those numbers do seem high. It's recommended to do the test cold or slightly warm, but only because removing the spark plugs on a hot, aluminum engine is risky(thread damage, stuck plug). Did you pull the fuel pump fuse and run it out of fuel prior to testing? That may have a slight effect, but I wouldn't expect much change in your results.
Different test equipment can give different results also. If you have access to a different tester, you could retest. I would expect numbers in the 140 - 180 range. High compression like you are seeing may be the result of carbon buildup on the piston.
My search here showed 1 other with similar results, but the thread was a dead end.
https://www.chevyhhr.net/forums/prob...ell-fix-40393/
2smokey
Aug 12, 2015 12:12 PM
bhamsoxfan
Nov 22, 2013 11:51 AM
