An ECM question
Old Jul 13, 2017 | 10:46 PM
Dustin Phelps's Avatar
An ECM question
So I see someone said you can't use a 2 plug ecu on a 2.4l but can you use a 2.4l ecu on a 2.2l which doesn't require that plug normally? I'm just curious because I believe my ecu got fried when a bunch of wires melted together, after replacing the entire engine harness the car just cranks but never fires, seems it's getting no fuel pressure to the rail.
Old Jul 14, 2017 | 12:44 AM
to the forums, Dustin!!
Have you checked the fuse for the fuel pump?
Old Jul 14, 2017 | 08:10 AM
I see you have a 2011 the computer numbers need to match up to the VIN
https://www.rockauto.com/en/catalog/...computer),2896
Old Jul 14, 2017 | 08:27 AM
Sorry, I don't get what you mean. Did you install a 3 plug where there used to be a 3 plug? Did you use the old ECM?
Why do you think your problem is related to the ECM?
It would probably be better to start a new thread.
Old Jul 14, 2017 | 08:35 AM
I moved to a new thread, for clarity.
allman
Aug 10, 2009 09:32 PM
ludicristSS
2.2L Performance Tech
11
Mar 7, 2007 08:38 PM
Bowtie388SBC
2.4L Performance Tech
May 24, 2006 06:32 PM
ludicristSS
14
May 4, 2006 01:55 PM
snksknr94
Jan 23, 2006 04:14 PM
