Coolant Leak
Old Mar 12, 2025 | 02:47 PM
guppy's Avatar
Coolant Leak
2008 HHR LS
Had a minor coolant leak from bottom of upper radiator hose. I just replaced both upper radiator hose, reusing the factory radiator hose clamps. I drive it 15 minutes to work and notice coolant still leaking from bottom of short radiator hose. Are the factory clamps known to leak? I plan to replace them with worm gear clamps tomorrow or is there something that I need to be looking at? Thanks
Old Mar 12, 2025 | 03:26 PM
The filler neck itself cracks and crumbles.
Old Mar 12, 2025 | 03:31 PM
Filler neck! Try the worm gear clamps first
Old Mar 13, 2025 | 07:56 PM
guppy's Avatar
Removed the four factory hose clamps and installed the correct size (43mm or 1-3/4") stainless worm gear clamps. Put the gear on bottom so you do not see it, correct size so it does not have a tab poking out. Looks Great.
Still freaking leaks!!!
I suspect the radiator cap, O-ring looks nice and smushed. I'll probably just order both the fill neck Tee and the radiator cap from amazon.
Old Mar 14, 2025 | 07:41 AM
They come as a unit
https://a.co/d/68pTwD3
Old Mar 19, 2025 | 04:49 PM
guppy's Avatar
Last thing I bought was a plastic filler neck. That fixed the leak! On a good note, everything there needed replaced anyways. Sorry, I had already ordered the plastic neck before I saw the steel neck recommendation. Thanks
Old Mar 19, 2025 | 05:27 PM
Plastic is fantastic, but steel is real and aluminium is way cooler!
Old May 24, 2025 | 12:02 PM
Think it's time for mine to get replaced, tiny drip, looks like from cap, but wiped & left overnight, wet near the angle that pipe goes upward to cap.
Finding replacement, not so easy...But ordered.
Old Jun 15, 2025 | 02:54 PM
New OE pressure cap seems to have done the trick...
Old Jun 15, 2025 | 04:21 PM
Keep an eye on the filler neck.
