Coolant and oil loss
Old May 22, 2023 | 06:42 AM
I confirmed in another thread about oil consumption you have a 2008 2.2 litre , so I moved this to its own current thread.
Old May 22, 2023 | 06:44 AM
Check the pcv hose at the rubber elbow to the throttle body, sometimes oil gets ingested there.
Old May 22, 2023 | 07:16 AM
greg8453's Avatar
ECT sensor may be bad.
Old May 22, 2023 | 07:19 AM
greg8453's Avatar
What good is this thread?
Old May 22, 2023 | 07:25 AM
Anyway, the answer is drum roll please: a new ACDelco 131-158 thermostat, no other part number.
Open the pressure cap to check coolant level frequenly.
Since you said in another thread that you are losing oil; you should suspect bad rings, 2 quarts in 2 weeks is a lot. Check it very frequently.
Old May 22, 2023 | 12:52 PM
Please read FMG and RJ’s response posts on page one.
Greg, I confirmed the engine in question is not a 2.0 LNF turbo engine, that’s why I separated the threads also the other thread was from over a decade ago, doubtful any responses would be posted.
Old May 22, 2023 | 05:58 PM
Lionweeb's Avatar
THanks. But idk how I am posting And idk how to do new thread 🧵😞. Are you all on Facebook group?
Old May 22, 2023 | 06:12 PM
Lionweeb's Avatar
Thank you for reposting.
to the forums!
98% of the time, this is a bad thermostat issue. Get the ACDelco 131-158, accept no substitute. Here is the how-to https://www.chevyhhr.net/forums/how-...l-p0128-24493/
Thanks again. I'm new and try to find my way around here.
Old May 22, 2023 | 06:57 PM
Ok, I've moved all of your posts to this thread. So now oil loss is noted here, so our answers are a little bit muddled.
The thermostat suggestion addresses the issue you have with the flatline coolant temperature readout.
Old May 22, 2023 | 07:01 PM
I’m not in FB , we are here on chevyhhr.net
