Chevy HHR Network
-   -   Coolant recovery tank replacement (https://www.chevyhhr.net/forums/problems-service-repairs-42/coolant-recovery-tank-replacement-54694/)
redhhr08 Oct 7, 2015 10:48 AM
Hello. I have a 2008 Chevy HHR LT 2.2 liter. I noticed the other day I have a crack in the bottom of my coolant recovery tank. Can anyone please tell me the process to take that out and put a new one in? Thank you.
whopper Oct 7, 2015 11:05 AM
https://www.chevyhhr.net/forums/prob...k-leaks-50650/
redhhr08 Oct 8, 2015 02:05 PM
Thank you for your answer. Can you tell me exactly where the bolt is I need to remove?
Oldblue Oct 8, 2015 02:25 PM
From the black cap follow the neck down and that bolt is off to the side of the neck
redhhr08 Oct 10, 2015 08:16 AM
Thank you very much.
Ronnie Aug 17, 2020 10:56 AM
I also just now installed a replacement coolant recovery tank!
https://cimg8.ibsrv.net/gimg/www.che...8a3de5359c.jpg
I also picked up this part at the junkyard over the weekend. I filled it with water to make sure there was no damage before I purchased it.
Getting the old one out wasn't as easy as removing one bolt. I had to remove the hose from the radiator as well to make room for it to come out. :cooldance:
sleeper Aug 19, 2020 09:25 PM
Cool Beans !!! I marked the level on my tank about 2 inches higher than factory. Their full line is too hard to see. I used a Sharpie. And easy to spot.
It doesn't overflow with A/C is off, so it is fine. Been running it this way for a decade at least.
tiapetra Aug 20, 2020 06:23 PM
The coolant itself is rather hard to see.
Best way I have found it just to use the light on my phone and hold it on the other side of the tank, shows up clear as can be.
firemangeorge Aug 20, 2020 07:34 PM
Yes. Hard to see with my old eyes. I replaced the lower half of the overflow hose with clear plastic tubing. I can now just look at that and see where the coolant level is.
https://cimg6.ibsrv.net/gimg/www.che...358adc83fc.jpg
sleeper Aug 20, 2020 08:21 PM
:george: Great idea. I still like the full level higher than the factory has it..
