Cracked Radiator
Old Jul 9, 2011 | 05:04 PM
c2vette's Avatar
Cracked Radiator
So car was using almost a quart of coolant every 60 miles. Took to dealer, cooling system and block held pressure which agreed with my observation that the hoses were hard when hot.
No detection of coolant in exhaust or oil. No observed leaks. Car runs super smooth.
Final step was to add fluorescent dye to coolant. After about 50 miles I can now see it on the side of the radiator, cracked either top hose fitting or near mounting bracket.
Odd thing is that it was losing that much coolant, but only while moving (maybe sealed when sitting still, but leaked under "vibration"). You would also think we could have seen it on the underside of the car, but no.
No wonder the service manual coolant loss troubleshooting section ends with "replace radiator" if all other sources are eliminated as culprits.
Old Jul 9, 2011 | 05:28 PM
Odd you never saw any steam......
Michael20832
Jun 24, 2011 10:20 AM
LawDog88
Feb 5, 2011 08:25 AM
09BlackSS
Jan 28, 2010 06:17 PM
crc
War Stories
Feb 9, 2009 06:39 PM
acm
Oct 5, 2006 12:20 PM
